Job does not wait for stored procedure to finish
I have imported an sql server 2008 stored procedure as a function. I am able to call the function in a script, and I can see from the log (and from trace) that the stored procedure executes. At some point during execution, data services thinks the stored procedure has finished and completes the job. I can tell from specific tables in the datastore that the stored procedure has not finished, and it never does finish.
Data services is returning ACTA_SP_OK for the return status and NULL for the error message. As far as data services knows, everything is fine.
I have tried calling the stored procedure two different ways:
.DBO.<sp_name>(null, $return_cd, $error);
and
sql(‘datastore’, ‘DECLARE @return_value int; DECLARE @param1 nvarchar(50); EXEC @return_value = dbo.sp_name @param1 = NULL; SELECT ‘Return Value’ = @return_value;’);
Both methods have the same result. I have confirmed with an ODBC trace that the stored procedure is running. I have confirmed that the user/pass combo I am using in the datastore has permissions to fully execute the stored procedure. I have created other stored procedures similar to the one in question and successfully run them in data services.
Anyone seen this kind of issue before? I’m going a little crazy. Thanks.
chadbrogan@ccbcu.com (BOB member since 2012-07-11)
Is it possible that the stored procedure is returning multiple result sets and DS thinks the stored procedure is complete after the first result set?
We figured it out.
The developer was printing massive SQL statements to the message window so he could troubleshoot the SP quickly. This worked fine inside a native SQL client, but the ODBC driver was bombing out as soon as the SP tried to print a 200 line sql statement.
I had the developer remove all the messages and the SP started working perfectly.
Of course, I had to do a SQL trace to figure all this out. My apologies for forgetting about this post. Thanks for the reply.
Thanks for the update. Glad to hear you resolved the issue.
