When BW Process Chain kicks off Data services job.In the management console I can see below logs.
At 06:15:41 - JOB: Starting job on job server host , port <3500>.
At 07:02:36 - It says -JOB: Job <Job_XXX_XXXX> of runid <2011082706154169008232> is initiated by user .
It takes nearly 45- 50 minutes to start the job.
and when job is assigned with user id and account . it takes 2 mins to complete job.
Can anyone help me with solution?
12.2) 08-27-11 06:15:41 (6900:8232) JOB: Reading job <Job_RS6000_FlatFile> from the repository; Server version is <12.2.2.3>; Repository version is <12.2.2.0000>.
(12.2) 08-27-11 06:15:41 (6900:8232) JOB: Current directory of job <Job_RS6000_FlatFile> is <D:\BusinessObjectsDataServices\bin>.
(12.2) 08-27-11 [b]06:15:41 /b JOB: Starting job on job server host , port <3500>.
(12.2) 08-27-11 07:02:36 (6900:8232) JOB: Job <Job_XXX_XXXX> of runid <2011082706154169008232> is initiated by user .
(12.2) 08-27-11 07:02:36 (6900:8232) JOB: Processing job <Job_XXX_XXXX>.
is you DS repo in SQL Server Database ? if yes, then there was a fix done in 12.2.3.1 for this issue, there was problem with database lock on DS Repo tables
check the following post
the latest Fix Pack for 12.2 is 12.2.3.2, next FP 12.2.3.3 will be available in couple of week
DS Database type is SQL Server. Yes it was working earlier it was taking 2 mins. from two days it is taking 1 Hr . 2 Hr and today it took 4 Hrs to execute the job. And the problem is the same.
12.2) 08-28-11 [b]12:00:52 /b JOB: Starting job on job server host , port <3500>.
(12.2) 08-28-11 16:06:25 (5692:8228) JOB: Job <Job_RS6000_FlatFile> of runid <2011082812005256928228> is initiated by user .
We are executing jobs from BW Process chain.
Kindly help me.
