JDBC Connection using Oracle 10 JDBC Driver
I am facing an issue with setting up a connection with Oracle 10g JDBC Driver Access Definition.
I keep on getting this error
CS: Java Class not found in classpath : com.businessobjects.connectionserver.java.drivers.jdbc.wrapper.JDBCWrapper
I have already corrected my jdbc.sbo setting and its Oracle 10g setting is
com.businessobjects.connectionserver.java.drivers.jdbc.oracle.OracleDriver
C:/oracle/product/10.2.0/client_1/jdbc/lib/ojdbc14.jar
oracle.jdbc.OracleDriver
jdbc:oracle:thin:@$DATASOURCE$:$DATABASE$
Oracle
oracle_jdbc.setup
oracle
oracle
oracle
oracle
Query,Procedures
oracle10,oracle,jdbc
Always
My oJDBC.Jar file is kept @ C:\oracle\product\10.2.0\client_1\jdbc\lib. I have already changed “/” with “” and vice versa. Restarted my entire system also. Not sure what to do next.
Best Regards,
Kapil Uppal
kapiluppal :india: (BOB member since 2006-06-15)
Did you manage to get this resolved? I am getting the same error message.
rag1973
rag1973 (BOB member since 2010-07-08)
Anybody else with the same error and any known soultion ?
Naresh Ganatra :us: (BOB member since 2004-04-09)
try this solution, worked for me.
  <Class JARFile="dbd_jdbc,dbd_oracle">com.businessobjects.connectionserver.java.drivers.jdbc.oracle.OracleDriver</Class>
  <JDBCDriver>
			 <ClassPath>
E:\oracle\product\10.2.0\db_1\jdbc\lib\ojdbc14.jar
jdbc:oracle:thin:@$DATASOURCE${:$DATABASE$}
bilearn (BOB member since 2010-01-30)
