Hello,
I 'm trying to migrate to SDK4.2.
I’ve an issue when I try to do :
engine.openDocument(infoObject.getID())
The exception is :
com.businessobjects.sdk.core.CoreException: Unable to create an instance of class 'interface com.businessobjects.sdk.core.server.IServer' with qualifier 'cms.occa'
at com.businessobjects.sdk.core.internal.guice.GenericFactory.create(GenericFactory.java:115)
at com.businessobjects.sdk.core.Core.create(Core.java:520)
at com.businessobjects.sdk.core.server.internal.InstanceServerServiceImpl.createServer(InstanceServerServiceImpl.java:67)
at com.businessobjects.rebean.wi.impl.services.DocumentInstanceManagementServiceImpl.createServerCallerReader(DocumentInstanceManagementServiceImpl.java:854)
at com.businessobjects.rebean.wi.impl.services.DocumentInstanceManagementServiceImpl.openDocument(DocumentInstanceManagementServiceImpl.java:173)
at com.businessobjects.rebean.wi.impl.services.DocumentInstanceManagementServiceImpl.openDocument(DocumentInstanceManagementServiceImpl.java:82)
at com.businessobjects.rebean.wi.internal.WIReportEngine.openDocument(WIReportEngine.java:429)
at com.businessobjects.rebean.wi.internal.WIReportEngine.openDocument(WIReportEngine.java:438)
at com.lombard.reportengine.businessobjects.impl.BODocumentCreator.executeSpecificReport(BODocumentCreator.java:85)
at com.lombard.reportengine.connector.impl.BusinessObjectsConnector.createReport(BusinessObjectsConnector.java:147)
at com.lombard.reportengine.connector.impl.ReportProviderConnectorFactory.getIReportProviderConnector(ReportProviderConnectorFactory.java:117)
at com.lombard.reportengine.services.impl.ReportEngineStartupServiceImpl$1.call(ReportEngineStartupServiceImpl.java:87)
at com.lombard.reportengine.services.impl.ReportEngineStartupServiceImpl$1.call(ReportEngineStartupServiceImpl.java:67)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:662)
Caused by: com.google.inject.ConfigurationException: Missing binding to com.businessobjects.sdk.core.server.IServer annotated with @com.google.inject.name.Named(value=cms.occa).
at com.google.inject.InjectorImpl.getProvider(InjectorImpl.java:696)
at com.google.inject.InjectorImpl.getInstance(InjectorImpl.java:724)
at com.businessobjects.sdk.core.internal.guice.GenericFactory.create(GenericFactory.java:113)
My code:
logger.info("Starting creation of document " + infoObject.getTitle());
try {
final ReportEngine engine = (ReportEngine) session.getService("", "WebiReportEngine");
logger.debug("WebiReportEngine service " + engine.getVersion() + " available.");
final DocumentInstance doc = engine.openDocument(infoObject.getID());
doc.refresh();
// setting report input parameters
final Prompts prompts = doc.getPrompts();
if (prompts != null && prompts.getCount() > 0) {
BOPromptsSetter promptsSetter = new BOPromptsSetter();
promptsSetter.setPrompts(prompts, userInputParameters);
// now activate previously set input parameters
boolean reportOk = setDocumentInstancePrompts(doc);
If anyone have an idea or a solution, it is more than welcome.
codemewithfun (BOB member since 2017-02-15)
(BOB member since 2002-08-29)
(BOB member since 2011-10-14)
