Issue
Hi Gurus,
i have report with prompt, when i click modify is throw prompt to enter but when i schedule the report and click latest instance, is not throwing prompt to enter…wat should be the problem…can anyone help me in this
Diggydee (BOB member since 2009-08-27)
Seeing latest instance means, you are just seeing the report. There is no problem with the report.
For updating the report, you have to go to original report.
MightyBO :us: (BOB member since 2007-06-28)
When you want schedule the report, schedule it with required parameters.
Report runs at scheduled time with available parameters. It doesn’t prompt for values.
When you are scheduling report, It is assumed that there is no user intervention at execution time.
atulagautam (BOB member since 2009-08-31)
