I am trying to refresh a metric. I tried various options:
Manually just hitting the Refresh button under Dashboard Manager–>Metrics–> “Metric_Name”. This wont reflect a new Last Refresh date. But if I hit purge first then it clears the dates in Metric History and then upon hitting Refresh the data Last Refresh date is reflected as desired.
Created a Rule for the Metric refresh: Every 0 Hr and 5 Min WHEN 1=1 = purge&&& refresh metric.
Upon seeing the histroy of this Rule in the Scheduler I see that all the schedules for refresh were successful but again the Last Refresh Date of the Metric History does not reflect the latest refresh timestamp as desired. -
Scheduled just the Metric on the Scheduler with Purge for all periods option and Refresh now option. Still I dont see the latest Last Refresh Date on the Metric History as desired.
As am trying this in the DEV environment there is no way in which I can validate if the data is really getting refreshed unless i insert some new records into the DB which I dont want to do. Is there any other way to confirm if the refresh of the Metric is successful or the Metric History last refresh date should reflect the latest timestamp? Am i missing something somewhere ???
Pls reply.
Cheers,
Sag.
sagarghamandi (BOB member since 2004-08-26)
