Sorry, if i am asking something very basic but since i am very new to crystal report i am not able to get over with the issue by myself.
I have some columns in a Dataset as below and it consist of certain records accordingly.
Columns
RoomTypeText , NoOfBedsAlloted , NoOfBedsPresent , NoOfstudentsPen
Data
A , 10 ,12 , 2
B , 20 , 30 , 10
C , 2 , 5 ,3
All I want is to map the value of NoOfBedsAlloted,NoOfBedsPresent and NoOfstudentsPendingAllotment depending on RoomTypeText.
I used “on change of” RoomTypeText and put the other three fields in the “show value” section but it takes “count of NoOfBedsAlloted” which is not required.
The Don’t Summarize check box shows disabled and I cannot check that also. It is uncheck by default.
Hope i could clear my problem.
Please assist urgently.
Thank you in advance for all your support.
amitmca (BOB member since 2011-02-10)
