I m new to this forum and also new to this DI tool.
I have an issue with a simple job which is loading the data into teradata.
Job design :
Flat file -------> Query Transform -------> Teradata
Source info : Flat file with comma delimited with 2 fields only
Query Transform info : direct mapping
Target Teradata info : chosen Multiload as Bulkloader option and file option is data File and Bulk operation is Insert.
But when I choose the normal load(Bulk Loader option as None) , the data gets loaded into the teradata table.
By setting up all these for MLOAD ,i m not able to populate the data in the teradata table.I m getting the following errors.
|Data flow New_DataFlow4|Loader Query_TEST_TD
Teradata failed with the following error: <
UTY1006 CLI error: 303, CLI2: BADLOGON(303): Invalid logon string.
. Please run with script <D:/Program Files/Business Objects/BusinessObjects Data
Services/log/bulkloader/TD_DS_SGAM_DB_TEST_TD.ctl> on the command line to debug or notify Customer Support.
Services/log/bulkloader/TD_DS_scott_TEST_TD.ctl> on the command line to debug or notify Customer Support.
Sam
sam_pat (BOB member since 2010-08-27)
