unable to see the attached files… let me paste
2014-09-17 08:57:14 Commons Daemon procrun stderr initialized
Sep 17, 2014 8:57:44 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: E:\Windows\SysWOW64\;E:\Program Files (x86)\SAP BusinessObjects\SAP BusinessObjects Enterprise XI 4.0\win64_x64\jre\bin\
Sep 17, 2014 8:57:50 AM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8080"]
Sep 17, 2014 8:57:50 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 7097 ms
Sep 17, 2014 8:57:51 AM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
Sep 17, 2014 8:57:51 AM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.32
Sep 17, 2014 8:57:51 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\AdminTools
Sep 17, 2014 8:57:53 AM org.apache.catalina.startup.SetContextPropertiesRule begin
WARNING: [SetContextPropertiesRule]{Context} Setting property 'debug' to '0' did not find a matching property.
Sep 17, 2014 8:57:54 AM org.apache.catalina.startup.SetContextPropertiesRule begin
WARNING: [SetContextPropertiesRule]{Context} Setting property 'trusted' to 'false' did not find a matching property.
Sep 17, 2014 8:58:08 AM org.apache.catalina.util.SessionIdGenerator createSecureRandom
INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [109] milliseconds.
Sep 17, 2014 8:58:08 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\BOE
Sep 17, 2014 8:58:08 AM org.apache.catalina.startup.SetContextPropertiesRule begin
Sep 17, 2014 8:58:13 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://java.sun.com/jstl/core_rt is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/core is already defined
INFO: TLD skipped. URI: http://java.sun.com/jstl/fmt is already defined
Sep 17, 2014 8:58:17 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: /WEB-INF/cetaglib is already defined
Sep 17, 2014 8:58:18 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:58:19 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:58:20 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://jakarta.apache.org/struts/tags-template-1.0 is already defined
Sep 17, 2014 8:58:21 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:58:24 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: taglibrary is already defined
Sep 17, 2014 8:58:50 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://www.businessobjects.com/jsf/cmcappactions is already defined
Sep 17, 2014 8:58:52 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:12 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:13 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:14 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:15 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:18 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:19 AM org.apache.catalina.startup.TaglibUriRule body
Sep 17, 2014 8:59:32 AM org.apache.catalina.startup.TaglibUriRule body
INFO: TLD skipped. URI: http://jakarta.apache.org/struts/tags-logic is already defined
INFO: TLD skipped. URI: http://jakarta.apache.org/struts/tags-bean is already defined
Sep 17, 2014 8:59:38 AM org.apache.catalina.session.StandardManager doLoad
SEVERE: IOException while loading persisted sessions: java.io.EOFException
at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2320)
at java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:2789)
at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:789)
at java.io.ObjectInputStream.<init>(ObjectInputStream.java:287)
at org.apache.catalina.util.CustomObjectInputStream.<init>(CustomObjectInputStream.java:58)
at org.apache.catalina.session.StandardManager.doLoad(StandardManager.java:246)
at org.apache.catalina.session.StandardManager.load(StandardManager.java:204)
at org.apache.catalina.session.StandardManager.startInternal(StandardManager.java:491)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5294)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1105)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1664)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:439)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:761)
Sep 17, 2014 8:59:38 AM org.apache.catalina.session.StandardManager startInternal
SEVERE: Exception loading sessions from persistent storage
Sep 17, 2014 9:01:35 AM org.apache.catalina.core.ApplicationContext log
INFO: [WARNING] Could not load resource: null
Sep 17, 2014 9:02:15 AM com.sun.faces.config.ConfigureListener contextInitialized
INFO: Initializing Mojarra (1.2_16-20110421-1728-SNAPSHOT) for context '/BOE'
Sep 17, 2014 9:02:20 AM com.sun.faces.spi.InjectionProviderFactory createInstance
INFO: JSF1048: PostConstruct/PreDestroy annotations present. ManagedBeans methods marked with these annotations will have said annotations processed.
Sep 17, 2014 9:03:03 AM org.apache.cxf.transport.servlet.CXFNonSpringServlet loadBusNoConfig
INFO: Load the bus without application context
Sep 17, 2014 9:03:04 AM org.apache.cxf.transport.servlet.AbstractCXFServlet replaceDestinationFactory
INFO: Replaced the http destination factory with servlet transport factory
Sep 17, 2014 9:03:06 AM org.apache.cxf.endpoint.ServerImpl initDestination
INFO: Setting the server's publish address to be /
Sep 17, 2014 9:03:08 AM org.apache.cxf.jaxrs.utils.ResourceUtils getResourceStream
WARNING: No classpath resource classpath:/RaylightService.xsd is available on classpath
Sep 17, 2014 9:03:10 AM org.apache.cxf.transport.servlet.CXFNonSpringServlet loadBusNoConfig
Sep 17, 2014 9:03:13 AM org.apache.cxf.transport.servlet.AbstractCXFServlet replaceDestinationFactory
Sep 17, 2014 9:03:20 AM org.apache.cxf.service.factory.ReflectionServiceFactoryBean buildServiceFromClass
INFO: Creating Service {urn:services-businessobjects-com:coresdk:wsgateway}Gateway from class com.businessobjects.services.coresdk.wsgateway.GatewayPort
Sep 17, 2014 9:03:22 AM org.apache.cxf.endpoint.ServerImpl initDestination
INFO: Setting the server's publish address to be /Gateway
Sep 17, 2014 9:03:29 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\BusinessProcessBI
Sep 17, 2014 9:03:29 AM org.apache.catalina.startup.SetContextPropertiesRule begin
Sep 17, 2014 9:03:43 AM org.apache.catalina.startup.ContextConfig validateSecurityRoles
INFO: WARNING: Security role name noaccess used in an <auth-constraint> without being defined in a <security-role>
Sep 17, 2014 9:03:48 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\clientapi
Sep 17, 2014 9:03:48 AM org.apache.catalina.startup.SetContextPropertiesRule begin
Sep 17, 2014 9:03:58 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\docs
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\dswsbobje
Sep 17, 2014 9:03:58 AM org.apache.catalina.startup.SetContextPropertiesRule begin
Sep 17, 2014 9:04:34 AM org.apache.catalina.startup.ContextConfig validateSecurityRoles
INFO: WARNING: Security role name SAPRole used in an <auth-constraint> without being defined in a <security-role>
Sep 17, 2014 9:04:39 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\host-manager
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\manager
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\MobileBIService
Sep 17, 2014 9:04:39 AM org.apache.catalina.startup.SetContextPropertiesRule begin
Sep 17, 2014 9:05:04 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\MOBIServer
Sep 17, 2014 9:05:04 AM org.apache.catalina.startup.SetContextPropertiesRule begin
INFO: Deploying web application directory E:\Program Files (x86)\SAP BusinessObjects\tomcat\webapps\ROOT
Sep 17, 2014 9:05:04 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Sep 17, 2014 9:05:04 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 434233 ms
Sep 17, 2014 9:09:48 AM org.apache.coyote.AbstractProtocol pause
INFO: Pausing ProtocolHandler ["http-bio-8080"]
Sep 17, 2014 9:09:48 AM org.apache.catalina.core.StandardService stopInternal
INFO: Stopping service Catalina
Sep 17, 2014 9:09:48 AM org.apache.catalina.session.StandardManager stopInternal
SEVERE: Exception unloading sessions to persistent storage
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.checkValid(BundleContextImpl.java:1000)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getServiceReference(BundleContextImpl.java:601)
at com.businessobjects.http.servlet.internal.servlet.ServletBridgeObjectStreamFactoryImpl.createOutputStream(ServletBridgeObjectStreamFactoryImpl.java:25)
at com.businessobjects.servletbridge.session.BobjWebSessionMap.writeMap(BobjWebSessionMap.java:265)
at com.businessobjects.servletbridge.session.BobjWebSessionMap.writeObject(BobjWebSessionMap.java:247)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:953)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1482)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1413)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1159)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:329)
at org.apache.catalina.session.StandardSession.writeObject(StandardSession.java:1671)
at org.apache.catalina.session.StandardSession.writeObjectData(StandardSession.java:1077)
at org.apache.catalina.session.StandardManager.doUnload(StandardManager.java:432)
at org.apache.catalina.session.StandardManager.unload(StandardManager.java:353)
at org.apache.catalina.session.StandardManager.stopInternal(StandardManager.java:518)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5474)
at org.apache.catalina.core.ContainerBase$StopChild.call(ContainerBase.java:1575)
at org.apache.catalina.core.ContainerBase$StopChild.call(ContainerBase.java:1564)
Sep 17, 2014 9:09:48 AM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
SEVERE: The web application [/dswsbobje] appears to have started a thread named [Timer-1] but has failed to stop it. This is very likely to create a memory leak.
Sep 17, 2014 9:09:48 AM org.apache.coyote.AbstractProtocol stop
INFO: Stopping ProtocolHandler ["http-bio-8080"]
[Moderator Edit: Added code formatting - Andreas]
ksiddiqui (BOB member since 2014-06-16)
