Thank you to Christophe & Michele for your ideas. They work OK with a limited number of objects but will be too labor-intensive for reports with up to 100 objects.
Maybe BusinessObjects can add a configurable-setting for this in a future release.
Thanks, George Baranowski
Name Sex Age City State
Smith, Dianne F 71 Chicago Illinois
Put a break on (that may be useful) Then insert 4 rows under the name cell.
Drag and drop each object (, , , ) in each of you new rows.
Then delete your 4 unuseful columns, and insert a colums on letf on your single-column table.
In this new column, you type your titles (Name, Sex, etc …).
