I have a date field that I am trying to determine number of as days since that day. I used DaysBetween(CurrentDate();MyDate) and then just subtracted them CurrentDate() - MyDate. I get “#Format” returned as value. So I did IsDate(MyDate) formula and it’s also returning “#Format”. I created a variable ToDate(MyDate;“MM/dd/yyyy”), then FormatDate(ToDate(MyDate;“MM/dd/yyyy”);“MM/dd/yyyy”), still getting “#Format” value returned. Ug!
What is MyDate? Is it a universe object or a report level variable? If the latter what is its formula? And what type is MyDate of? Can you also give some values as an example?
Hello,
“MyDate” is a universe field that is a date. I looked at the Oracle database schema behind the universe, and it is indeed formatted as a date (timestamp 26), and the universe is not modifying it in any way, so I’m not sure why BO’s currentday() field and this date field aren’t playing together.
An example: 02/17/2010
“MyDate” is always MM/dd/yyyy
