ng it as version 4?
I have developed a VB script for Emailing BO docs. The script sits on our BCA as a VBA Add-In. However, I have one remaining problem, whereby when the script refreshes, saves and sends a V4 doc, it converts the doc to V5. I would like the script to refresh and send V4 docs as V4 and not convert them to V5 in the process.
Now I do know the BCA can refresh V4 docs (preserving them as V4) when choosing a the Refresh Action when sending the doc to a BCA from a 4 client - and have done this. However, when I try and do the same thing within my VB code it coverts a V4 doc to V5, i.e.
V4 doc in
V
doc.refresh
doc.save
… followed by my procedure for sending via MAPI
V
V5 doc out!
I think that when I omitted the doc.refresh action out, doing this by choosing the Refresh Action when scheduling it did send the doc as V4, unfortunately when trying this method out it simply sent unrefreshed V4 doc (i.e. the script wasn’t actually picking up refresh doc) … anyway I would prefer the V4 user not to have to select the Refresh option.
Anyone out there got any ideas???
Is there a way to doc.refresh & doc.save within a VB script running on the BCA preserving it’s V4ness?
Alternatively is there a tool out there that can downgrade a V5 doc to V4?
Daniel.
