Hi I’m using BOXI R2 Environment- In CMC Is there a way I can export List of Groups/Users/Objects to Excel
Please let me know any Experts in this issue
Madu (BOB member since 2008-02-08)
Check BOB’s Download section where you can find few utilities that will help you:
http://www.forumtopics.com/busobj/viewforum.php?f=25
You can use the Audit DB.
Also, this will help
Diamond (BOB member since 2009-08-26)
Hi guys,
I’m using this link which is having VBA code to pull the groups and so on. I’m getting an error like this “Compiler Error” → User - Defined type not defined… please find the attachemnt to the same
Is any Expertise know this issue
Do you have BOE clent installed on your laptop (client machine)?
Yes… it install BOXI R3
