Is there a document out there that gives an example of migrating a report using UNV universe to point to a UNX universe
I thought I had a document that will assist in step by step migration of a report using a UNV universe to point to a UNX universe.
Sadly, I cannot find it and hoping someone has one laying around!?
You can change a data source in any Web Intelligence document using the Change Data Source wizard built into the Web Intelligence toolbar. To convert documents at scale, SAP provides the Automation Framework (BI 4.2) or Workflow Assistant (BI 4.3), and there are multiple partner solutions, as well. Remember that you must convert universes from UNV to UNX on version 4.3, as BI 2025 is purely 100% UNX with no conversion tools.
Thanks, I was hoping to find something similar that I had that uses an Excel Spreadsheet and it runs a VB Script returning Repository Information such as Folders, Reports, Universes used… But it doesn’t go down to the REPORT level to identify the columns. This I am doing it manually right now unless I can find a utility or possibly update the Repository one I have to break down each Webi report and retrieve the columns.
Tedious to do it manually looking at one report at a time :frowning:
For large volumes of universes and/or reports, I would investigate solutions from Wiiisdom/360Suite and APOS rather than doing it manually.
