The SAP support note - 1287906 - How to determine the version number of an XI Release 3.x in Windows
says
Symptom
How to determine the version number of an XI Release 3.x rather than from Add/Remove Programs.
Cause
The version number shown at the application level in the Help > About menu does not get updated by the setup.exe in Fix Packs or Service Packs.
Resolution
Browse to the drive where you installed Desktop Intelligence.
For example: C:\Program Files\Business Objects\BusinessObjects Enterprise 12.0\win32_86
Right-click the busobj.exe file, click Properties then click the Version tab.
More Information
The following list shows what the version numbers should be depending on which patch combination you have:
BO XI 3.0 12.0.0.683
BO XI 3.0 + FP1 12.0.0.796
BO XI 3.0 + FP2 12.0.0.840
BO XI 3.0 + FP3 12.0.3.900
BO XI 3.1 12.1.0.882 or 12.1.0.914
BO XI 3.1 + FP1.1 12.1.1.957
BO XI 3.1 + FP1.2 12.1.2.996
BO XI 3.1 + FP1.3 12.1.3.1028
BO XI 3.1 + FP1.4 12.1.4.1068
BO XI 3.1 + FP1.5 12.1.5.1096
BO XI 3.1 + FP1.6 12.1.6.1116
BO XI 3.1 + FP1.7 12.1.7.1144
BO XI 3.1 + FP1.8 12.1.8.1176
BO XI 3.1 + FP1.9 12.1.9.1290
BO XI 3.1 + FP1.10 12.1.10.1390
BO XI 3.2 12.2.0.290
BO XI 3.2 + FP2.1 12.2.1.412
BO XI 3.2 + FP2.2 12.2.2.441 or 12.2.2.453
BO XI 3.2 + FP2.3 12.2.3.467
BO XI 3.2 + FP2.4 12.2.4.507
I have always known 3.1+SP2, as 3.2, as per the list, I can’t remember whether you can get this as a single install.
However, it should be the same as a base 3.1install with SP2, applied.
No problem :).
Support dates are, always subject to change, think how long they supported 6.0, although, admittedly, you had to pay for this later.
Controversial, I believe you will still see it in 4.0, some folks just don’t want to make the move, or are concerned about functionalities that have, yet, to make the Webi or Rich client.
