As per my requirement I should display list box in report and which contains data based on filter values.
Eg::
List box data::
US
IND
UK
below I have table
[/list]
BOCP (BOB member since 2007-07-02)
Eg::
US
IND
UK
[/list]
Is the filter at the query Level or the report level?
Is it based on User Response / Prompt?
Mak 1 (BOB member since 2005-01-06)
Report level and no UserResponse and Prompts…!!
It contains formula that’s it.
Current table is of type :: Cross Tab (With rows and Columns)
I should display all the Rows in list box.
Thanks[/quote]
Try adding drill filters. It should work.
Select the drill section. And drop the object or varaible in that section. This will show the list box in the report with all the values in the object which are selected in the report.
GowthamSen (BOB member since 2006-08-31)
