Is it possible to run and export a Free Hand SQL source Webi with Report Engine ?
I am trying to run a webi document and export the result to CSV etc using BO Java Report Engine SDK
The webi is created using Free-hand SQL as the datasource
IEnterpriseSession enterpriseSession = getSessionFactory().getSessionInstance();
ReportEngine wiRepEngine = getReportEngine(enterpriseSession);
DocumentInstance inst = wiRepEngine.openDocument(Integer.parseInt(instance));
Report report = inst.getReports().getItem(0);
DataProvider dp = inst.getDataProviders().getItem(0);
When I try to get the DataProvider I get the following error message
Caused by: com.sap.sl.sdk.datasource.strategy.DataSourceStrategyException$DataSourceStrategyNotRegisteredException: No concrete data source strategy registered for data source type “FHSQL” and data source sub type"".
alexuyus (BOB member since 2014-07-24)
