interview question
i have recently went to some interview in an mnc company,they have asked me this questions
1)They are 2 tables A & B with 2 joins does it
create loop between them?with example?
2)what do u mean by merge dimention?
3).difference between cmc and supervisior?
if anybody knew answers to these questions please give me answers
thank you…srinivas
srinivasaraoy (BOB member since 2007-12-11)
Yes, it does create a closed path. However, it doesn’t produce the effect of a loop. For loop to have its effect, there should be a dimension table which is shared, creating a double restriction and limiting the records.
Merging is the process of creating a link between two queries, based on an object that has common values so that the object becomes ONE.
A difference of Chalk and Cheese.It’s like comparing apple and orange.
zack :us: (BOB member since 2007-08-02)
This forum is not for Discussing about the Interview Questions, requesting you to avoid such questions. For your reference, just have a look on the links, it will help you to get more idea.
Siva.M
looksmee :uk: (BOB member since 2006-02-08)
Very true.
This topic is now locked.
