Internet Explorer 11 and BO 3.1
Has anyone been successful in getting Business Objects 3.1 SP5 or 6 to work with IE 11? Our desktop folks want to move to IE 11.
I see on the SAP website that IE 11 is not a supported platform. But has anyone been able to get it to work?
hunt4fun :us: (BOB member since 2009-08-27)
It looks like you should patch it with SP7.
http://evtechnologies.com/state-of-the-sap-businessobjects-bi-4-0-upgrade-april-2014/
It may work in compatability mode.
In our case though even though IE 11 was stated to be partially supported for 4.1 SP2 it didn’t work in our case. Unsure what the exact issues were as this testing was carried out by the apps team that support the installs / patches.
Not sure if this will help you out at all, but IE11 offers a feature called Enterprise Mode. It’s brand new in one of the latest IE cumulative patches. This is/was intended to help enterprises move off of IE8 and onto at least IE11. The functionality allows for some websites that are identified to be rendered in IE8.
We tried it with our SP3/Tomcat 5.5 environment, but no dice. We are investigating an SP7/Tomcat 7 upgrade and will try again.
dusted (BOB member since 2003-09-18)
I’ve installed SP7 and IE11 and they do work together. But this latest comment is worth a try in case the desktop group want to move ahead of the BO upgrade.
Thanks!
Just an observation;
XI3.1 SP7 and IE11 work flawlessly and (I personally think) SP7 is the best service pack ever released for 3.1.
Cheers,
Jim
jwaterbury :us: (BOB member since 2007-09-21)
jwaterbury - Does the schedule for BOE 3.1 SP7 work properly with IE 11 ? We have gotten an 404 using BOE 3.1 SP5 we are looking move to SP7.
Also, what version of BOE 3.1 were you on before going to SP7?
kflknr (BOB member since 2014-05-30)
kflknr,
We were also at BOE 3.1 SP5 and yes, we got the 400 or 404 errors when clicking History, Scheduling, and a couple of others (using IE 10 or 11). No issues with either version after applying SP7. Go for it!
Jim
Thanks for your response, can I ask you a few more questions.
  1. Is your application in a clustered environment ?
  2. How many servers in the cluster ? Do you have a distributed environment more then 1 of the services running?
  3. Were there any issues installing the SP7 How long did it take ?
Thanks again
K
K,
We applied SP7 to a 3-server cluster. Outside of the CMS, FRSInput and FRSOutput; all services are distributed. Applying SP7 took about 4 1/2 Hrs. start to finish.
Jim
I was researching this issue as well and found this on SAp TECH SITE:
Support for IE 11 on Windows 7, Windows 8.1 and Windows Server 2012 R2 is planned for BI 4.1 SP03 and BI 4.0 SP09, both of which are available since March 2014.
Support for Windows 8.1, Windows Server 2012 R2, and Internet Explorer 11 is available for BOE XI 3.1 SP7 since April 2014.
our clients are windows 7, our java is 1.7, and our version 3.1 sp6 (windows server)…
we had a user who got a push to IE11 on wind7 laptop and Infoview would not allow a login.
are you using similar clients on your 3.1 sp7 version with IE11? Did you change the compatibility view on the clients?
thanks,
carol
carol.gottlieb (BOB member since 2008-10-01)
We are using similar clients yes: Windows 7, Java 1.6, but we are using BO 3.1 SP7 and we are able to use both IE8 and IE11.
Great. The SAP said it wouldn’t work with Win7, so I was a little concerned.
and you didn’t encounter any other issues like scheduling, editing, saving, etc?
Carol
No issues at all.
did you have to change the compatibility mode?
C
I believe we changed it to Enterprise, yes.
SUPER. Thanks for the INFO!!
C
Hello All
Has anyone specifically asked SAP support about using “BO 3.1 SP5” (or BI 4.1 SP1) with Internet Explorer 11’s Enterprise mode “EMIE”
We have built tools/automatin API plugins that will absolutely require updating if we have to service pack BO/BI
~Todd
tsimons_dti (BOB member since 2015-01-07)
If you are using BO 3.1 SP5 and IE 11, you should get problem when you select “Properties” on the WEBI reports (HTTP Status 400) and select “Properties/”“History” on publications (404).
summoner :hong_kong: (BOB member since 2008-12-18)
BO 3.1 SP5 will have issues with IE 10 and IE 11 is completely unusable.
Yep, we’ve seen this, but don’t see it when using IE11 Enterprise Mode (aka EMIE)
http://msdn.microsoft.com/en-us/library/dn640687.aspx
I was wondering if anyone had done a full test with this IE11/EMIE turned on
Thanks!
