interesting paradox on page breaks and headers
Hello everyone,
Wondering if anyone has run into this before and may have a solution: A report created in Full Client has several breaks. The report also has several columns that do not fit onto one page but are carried over onto new pages when printed. In order to get the report header information on every page including the new pages created by the vertical page breaks, the header information needs to be placed in the header section of the report. However, when this report is placed inWEBI and viewed the header report information/title do not display. Only data in the report sections.
If the report header information is placed in the lowest section then it is display on the web, however it does not display on a new page created when a vertical page break occurs such as when the columns spill over onto another page.
Jeff Falvey, Northeast Principal Consultant Business Objects Consulting Group
24 Wildwood Ave
Arlington, MA 02476
jfalvey@businessobjects.com
Office Phone: 781.643.5558
Office Fax: 781.643.5559
__________________________________________________ Jeff,
Try this. Instead of placing the information you want in the header place it at the top of the page. Then bring up the cell format dialog box. On the Alignment tab you have a check box at the bottom called Repeat on every page. This will then place this cell on every page both horizontal and vertical. This option is also available for tables. Hopefully this will help on the WEBI side also.
Glenn Fredericks
Data Warehouse Specialist
glenn_fredericks@aal.org
(920) 730-4700 x4236 or 1-800 CALL AAL
Aid Association for Lutherans
4321 N. Ballard Road
Appleton, WI 54919-0001
Visit our Web site at www.aal.org or e-mail us at aalmail@aal.org
AAL… Financial services. Lutheran heritage. A powerful combination.
Hi Jeff,
When records do not fit on a single page and you want to display the table header on other pages as well , select the table header and then from menu bar go to Format->Breaks and select “Repeat the header on the new page”.
This works fine in Business Objects but you may have to test it on WEBI. I hope it answers your query.
Good Luck.
Ashwani
