system
February 20, 2007, 11:39am
1
I just did a migration via the Import Wizard and I have a hunch that my source CMS/FRS may have been out of sync.
Is there a utility or CMC page that I can use to verify the integrity of my CMS/FRS?
In particular, I would like to verify that:
a. all files in my input/output FRS have a matching entry in my CMS database
b. all my objects in my CMS database with associated files in the input/output FRS do indeed have their matching files present
c. all my objects in my CMS database are accessible via CMC vs. being present in my database but orphaned from the standpoint of accessability
Thank you,
Bill
bgunn (BOB member since 2006-12-19)
system
September 6, 2013, 2:49am
2
Did you ever get an answer ??
r2ks (BOB member since 2013-09-05)
system
September 6, 2013, 2:04pm
3
I think you’re looking for the Repository Diagnostic Tool. This will identify files and repo records that are out of sync. There’s tons of posts on it. Here’s a couple.
https://bobj-board.org/t/109467
http://help.sap.com/businessobject/product_guides/boexir31/en/xi3-1_bip_repository_diagnostic_tool_en.pdf
ChrisW1204 (BOB member since 2011-04-21)
system
September 7, 2013, 12:45am
4
I looked in the directory where it state that it is located and it is not there can you tell me where I can get it for 11.5
