integration with Outlook
hi all, i’ve just installed Live Office in my laptop, I’ve tested it with MS Word and it works fine, but, after opening Outlook, the menu Live Office only shows 2 options: Help and About Live Office…
may i enable something? is there any tool to do such kind of things? because in Start>Programas->BO XI 3.1 i can’t see anything related to Live Office…
thanks all, i really appreciate your help!
adelsaz (BOB member since 2009-03-13)
ok, I’ve found the key, until i don’t create a new message I can’t see Live Office options in order to add reports, etc. :slight_smile:
Helloooo!
So you tell me that you can integrate Live Office in Outlook mails???
We have BO XI 3.1 and Live Office
I thought Live Office only worked in Excel, Word and Power Point
Can you integrate Live Office in a mail?
Victor
:nopity:
Victor_BCN :es: (BOB member since 2009-09-15)
You can add query results and report parts if you are dealing with a message; new or reply.
vonwolf :us: (BOB member since 2002-10-21)
The Outlook integration will ony show up if you’ve enabled it using the enable_addin.exe.
Which should be here: C:\Program Files\SAP BusinessObjects\SAP BusinessObjects Enterprise XI 4.0\LiveOffice
Select the Outlook tick and then you may need to restart office/outlook before it appears.
ladiesman217 (BOB member since 2013-01-29)
