Integration of BO with Lotus Domino
I want to integrate BO XI Professional Release 2 with lotus domino database for reporting purpose.
Is it possible to use Lotus Domino database as the database in BO?
Tushar Chhapia :india: (BOB member since 2009-07-01)
As per BO XI R2 Supported platforms, it can connect to lotus domino with Crystal Reports, are you looking for WEbI/Deski connectivity?
check platform.txt, you might get some idea on that
Nirav
nniravv :india: (BOB member since 2007-08-16)
Crystal comes with a Lotus Notes ODBC driver, has done for years. There was a time when Lotus bundled Crystal.
It gives you access to views and forms, although the performance was never very good due to Lotus architecture.
Using the same ODBC driver you`d probably be able to connect Webi up using a generic ODBC database connection.
Personally I would get the data out of Notes into a normal database for reporting on it.
From my own experience a few years back, I can only second that if your intention is to use WebIntelligence.
