Integrating Infoview into SAP portal
We have a enterprise SAP portal, which is used by the whole organisation,
We are currently maintaining a separate business objects system / Infoview for a particular department and the reports are developed using oracle and SQL server. The BO security is set up using the LDAP.
Now we want to embed the infoview into the SAP portal so that the users can log into our enterprise SAP portal and view the infoview screen, so that users can refresh the reports against oracle/SQL server and also the BO folder /category/security should remain the same as seen in current BO Infoview
varun (BOB member since 2007-07-10)
See https://bobj-board.org/t/141025
aneelf (BOB member since 2006-05-15)
