Installation probelm.
Hello
We are connecting db2 database from client station we cpoied Bomain and othe DB2 file from already installed m/c(which is working well. However we are connecting after this error.
Unhandelled Expection.
Code: c000005
Description:EXCEPTION_ACCESS_VIOLATION.
Please let me know possiable Reason for this error.
Thank you
Sree
______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
I have see that error in the context of a bad / damaged objects.lsi file - maybe copy over the current one with a backup, from your install set or another pc…
Just one possible cause, maybe I am lucky…
Brent
Code: c000005
Thank you
Sree
One of the reasons for the problem is the virtual memory , try to increase the VM and see , I hope it should work.
Dinesh
Hello
Code: c000005
Thank you
Sree
