I applied a patch to address the Java version issue - if you have newer than Jave build 18 Webi does not display the columns when you create a new report(aside from the blue and yellow columns that is)
The patch corrected the problem on one of my servers but when I tried to apply the patch to another server it seemed to have caused a problem with my sign-ons:
Normally we log on to a authentication link which once completed automatically brings up WEBI.
Now once you authenticate it brings up the InfoView portal and waits for you to log in again ?!
We are using Tomcat & IIS
I tried shutting down Tomcat, SIA and WWPS from the Central Configuration Manager then restarted them-still the same issue.
Any ideas?
And Thank you
di652 (BOB member since 2005-02-24)
