I need to install BO 6.5.4 on Solaris. It seems I have to install a base version of 6.5.1 and then apply Service Packs and/or hot fixes to subsequently upgrade to the required patch level? Apparently I need patch level CHF68, and I have access to a file 1400707085_68-20005010.tgz, which is about 405MB. My question is: will this contain ALL updates from 6.5.1, or do I also need to install a Service Pack beforehand?
Thanks in advance for any help you can give.
Matt
msmit207 (BOB member since 2003-03-04)
