I was installing some FP for LiveOffice after installing base version 3.1.
But,as I removed the installable for LiveOffice 3.1 after installtion it threw error file “liveOffice.msi” is missing .
Is it necessary to keep all the installable in the machine in the same location from where the installation is run first. As it keeps throwing one error or other if I move them or remove them after installation even if I am just installing a FP or SP for it.
No, these are the files that you can see as part of product installable.
But, I don’t understand why do I need to keep all the base installable in the same place in order to install the FPs or SPs over it.
Attached is one of such error when you remove/or move the installable.
Thanks Diamond that you noticed and welcomed me for BOB.
