I wonder if anyone else commiserate with me when trying to install BO 5.0.1 and have problems.
All is well and installing until it copies file BQAUT50.DLL, then the installation just pops out of it by itself without any errors messages or finishing the installation.
This is occurring with some PC’s, and not with others. Any ideas on what may be causing this?
All PC’s are in a Windows NT 4.0 and service pack 5.
Hi Edna,
You can search the archive and find some references to this problem which occurred on ver 5 and probably wasn’t fixed in 5.0.1.
In short, take down the services and close all the startup application.
Ronen Baran, System Analyst
Tecnomatix LTD.
Mail to : rbaran@tecnomatix.com
Telephone : 09-9594856
Hi all,
We found that an aborted install should be followed by removing the leftover BO directories and files manually; you can fight the install a long time if you don’t do this…
Good luck
Brent
Hi all,
You still use version 5? I’m tempted to make a joke, but seriously you are aware there are newer versions. Also version 5 is no longer supported by Business Objects.
