Insert and Delete records on Filters Drill
In a report of the need to insert WEBI Drill by Quarter. I need to show that the Drill “Q1, Q2, Q3 and Q4 and I do not have the option” all ". How do you remove the option all the filter available in the list leaving only Q1, Q2, Q3 and Q4?
pdsouza2008 (BOB member since 2009-10-14)
Do you not want ‘ALL’? If yes, I don’t think you can achieve it, as it is how it behaves by default.
No way.
There must be a way to remove the option “ALL”.
Yet discovered, but surely someone already did it.
