Input/Output exception occurred : 'error in opening zip file
I Created a QWAAS.And when I tired to click on the URL(QWAAS’s) it gives the following error :
Input/Output exception occurred : ‘error in opening zip file’
Kindly suggest a solution for this ?
Note : BOXI 3.1
Ramya.
Ramya.ksrj (BOB member since 2010-10-18)
We just got the same error today… Anyone know what causes this?
Charlie
CharlieBobj (BOB member since 2009-07-08)
No One has run across this, Wow I am suprised.
The issue is that the file (qaawsWsdl.zip) has become corrupted in regards to use in the QaaWS servelet. The zip file must be replaced with a new (cleaner) copy. This is how you do it…
Steps to correct issue:
  1. (On Tomcat Server location) Copy qaawsWsdl.zip file located in:
    %SERVER WEB APPLICATION DRIVE%\Program Files\Business Objects\Tomcat55\webapps\dswsbobje\WEB-INF\classes to safe location on server.
  2. Extract contents of copied zip file to a new folder.
  3. Delete qaawsWsdl.zip located in %SERVER WEB APPLICATION DRIVE%
    INF\classes
  4. Create new file, qaawsWsdl.zip in %SERVER WEB APPLICATION DRIVE%
    INF\classes and copy extracted files into new zip archive file.
  5. Navagate to:
    http://:/dswsbobje/qaawsservices/wsdlGenerator
  6. Log in as administrative user with CMS server name and run the WDSL
    generator to regenerate the WSDL content.
n5xjb :us: (BOB member since 2003-09-15)
Unlikely to get a reply as this is old. Thanks for the info n5xjb - this was very useful. A couple of questions if you are still around …
  1. Why do steps 2) and the second part of 4)? Potentially this is corrupted data and step 5) / 6) seem to regenerate everything anyway. So is there a reason for this?
  2. Any idea what can cause the corruption in the first place?
DanDensley :uk: (BOB member since 2009-05-12)
