Can we use Cascading LOVs with input controls?? If yes How??
Thanks for the help in advance
Poonam (BOB member since 2009-12-10)
The two concepts are not related. Cascading LOVs drive prompts. Input controls are on the report. What are you trying to accomplish?
Unfortunately not.
LOVs are used at the query level (in queries are in prompts). The input controls are effectively filters on the result sets so are completely separate.
dfoster99 (BOB member since 2010-11-05)
what i am trying to do
I have 5 input controls so what i want to do is when i select the first one it should filter out the rest 4 based on the selection.
for example
Country—>State—>City—>Zip code
when i select Country it should filter the state, city and zip code for that country only and then state should filter the city and zip code for just that state.
I hope that explains it better and thanks for the quick reply I really appreciate it.
Thanks in advance…
Drill filters are dependent on each other; input controls are not. You might try experimenting with drill filters instead.
In my opinion, this is a flaw that should be addressed in a future version. Has anybody played with input controls in BI 4.0 yet that can comment on this behavior?
i hate to say it, but you are describing Qlikview behaviour (I know, i will seek penance immediately ).
It may be for this kind of dynamic data exploration you need to look at a different product (I am deliberately not mentioning Explorer here as it doesn’t sound like a good fit)
Thanks for the feed back guys if it was xcelsius i would have done it with no problems but they want it done in webi… i did figure out a good work around that would cascade using input controls but its not 100% ready yet but will provide feed back once it is…
another question can we put a scroll bar on a data block…
So what i need to do is if the data block is returning 100 rows i just want to display 10 and put a scroll bar for them to see the rest
thanks in advance !!
no
Definitely a mismatch in reporting requirements and tool selection.
BTW do your clients know that you can upload Xcelsius dashboards into Infoview and view them alongside infoview reports?
Yes they do know that but we are returning 50000 rows of data… that wont work in Xcelsius
Ouch!
Hence the need for the smarter filtering or better summarisation before they need to look at the detail.
It might not be a bad idea to use both Xcelsius and webi.
I could use Xcelsius for input controls and high level and then detail in webi via opendoc…
what do you think??
I have proposed that idea to a client before. Using content-linking in a corporate dashboard between a dashboard doing the filter presentation and a webi report showing the data. The challenge would be that content linking can be cranky at the best of times.
Will keep that in mind thanks for the feed back
