I have Windows 2000 Server , and Service Pack 4 Installed
I have installed BO 6.5.
I created a cluster
I added an Application Server and Web Server under Infoview
I am trying to access the Infoview on the server itself not from a client
I have copied BOMAIN.key in locdata folder
I am using IIS server for Infoview
All the services are running, and I can see BO Server Started Icon on my task bar.
Problem 1: When I open Infoview, I see a page with login button. When I click login, it DOESNOT display login page, but shows lots of CODE. Why this problem happening.
Problem 2: Do I need both Application Server and Web Server, if I want to use Infoview and Webi from this Machine only?
Have you got the required connection to the repository on the webi server i.e TNSNAMES.ora for Oracle or System DSN for SQL Server etc? i.e ACn you log into Supervisor on the Webi box
Yes what I meant was does the TNSNAMES.ora file on the server have an entry for the Business Objects repository. It seems as though you have. What permissions do you have set up for the webi services?
I don’t think this will help with your current problem - but if you’re saying that your Oracle database is on the Business Objects server, you may have problems getting WebI to work. Ideally they should be on different machines.
I don’t have access to the Business Objects support site, so I’m not certain - but I don’t think it is supported. From experience - it may work, it may not. I wouldn’t put my production system on it, but I guess it depends how robust it needs to be.
