I have a report published on business objects which has been run around 210 times so far. When I look at the instances history in the infoview it’s not being sorted by date (even though the sort option for instance time is selected). Is there something I’m missing or is there a known bug in the system.
I have a similar problem with a date field. It is the only sorted field.
It doesn’t change if I adjust the number formatting from date/time format to number or vice versa.
Even though no other field is Sorted, it seems that one of the other fields actually is being sorted as the primary sort value, with the date being secondary. This happens also to be a unique value, a primary key (but with many 1-on-1 attributes such as the date field).
At some point it was a sort value and maybe the change to non-sort is not correctly updated in the repository, but I have no way to figure that out.
