infoview LOGO
HI ,
I want to change the infoview logo
Here infoview logo is showing Business objects and i want to show the some other name can u tell me the steps please
nsai
nsai (BOB member since 2007-03-27)
are you using jsp or asp files ?
Have a look in the page source the name and where the BO logo is stored, then, have a look at this file and replace it with the logo you want (carefull to the aspect ratio) or you will have to adapt the html code also
HI,
when frist time we open infoview it showing name is BUsiness objects now i want show diff name its possible to change
if yes what are the steps i have to follow please tell me
Nsai
In Business object installed server, search for businessobjectbanner115, change thatone to some other name, and place your logo with this name in the same folder.
Anandh (BOB member since 2006-07-06)
[quote:823e478266=“Anandh.s”]earch for businessobjectbanner115
[/quote]
It depends :?: :?: :?:
You have posted in webI 1/2x subforum… which webi release are you using ?
