InfoView Issue
I have a crystal report which i am trying to update the sub reports through Infoview. But i am not able to edit the sub report since the sub reports are in non editable mode. Please let me know if i need to do any setting change for editing the sub reports from InfoView
Thanks!!!
Chandran21 (BOB member since 2009-09-14)
You won’t be able to edit a Crystal Report in InfoView. When viewing a Crystal Report in InfoView, you are actually using the Crystal Reports Viewer software, not the Crystal Reports software itself. You will need to pull the report down from Business Objects into Crystal Reports to make any changes and then export it back out.
Thank you.
