Infoview Integration with Sap Portal
I searched the forum and not able to get the answer.My requirement is belwo
Client Wants to integrate Infoview with the SAP portal.I have gone through manuals regarding portal integration kit and here are the options they gave
1.Iview ----Placing the existing reports in the form of iviews in Sap Portal.Will this iviews have an option of sheduling the reports
2.KM—How an we use this to integrate with portal
or is there any way where we can give the infoview as link so that when teh user clicks on it it will take us to infoview using the roles and permsions that is defined for that user in SAP
kumar446 :india: (BOB member since 2006-01-23)
Hi Kumar,
You can configure to integrate SSO for BO and SAP Portal. See the following discussion.
https://forums.sdn.sap.com/thread.jspa?threadID=1406505
In addition, the following Ingo Hilgefort’s blog is also very helpful.
http://www.sdn.sap.com/irj/scn/weblogs;jsessionid=(J2EE3414900)ID1439204150DB21143212942253585299End?blog=/pub/wlg/11090
HTH
Richard.I.Saladin (BOB member since 2009-11-05)
