infoview customizing
hi guys,
i am new to web intelligence
can someone direct me or help me with any resources to customize the infoview where i can have links to different reports and whether i can pass parameters through that page?
thank you in advance.
imkoolkrab (BOB member since 2009-05-07)
Customizing InfoView generally requires you to modify the default pages (jsp, css, etc.) that come with the base product. The desktop.war file contains the files that are used to build the InfoView portal. You will need to understand how InfoView currently functions before you could make any changes.
jwhite9 :us: (BOB member since 2006-07-28)
You can check the below link:
Note: Play on your own risk. I tried and struggled a lot to roll back the default Business Objects scheme.
Thank you aniket. i will give a try.
