My company has just bought crystal server and crystal reports. I want to be able to create dashboards from the BO info view. I’m having some problems though.
Say i want to add a traffic light dash feature, i drag it to the workspace, then i click the little spanner to edit, then i try to click select data to display-> define query but nothing happens??
I’ve tried importing a crystal report and linking the 2 but i still can’t add any measures to the traffic lights.
Is there something i need to set up first??
Do i need a specific license to do this??
Do i have to use excelsius to do this, i was hoping not??
Can anyone please point me in the right direction, many thanks. spin
Dashboard required additional license
Crystal Reports server and crystal reports is only reporting solution
to design universe you need to have BusinessObjects Enteprise license which has Universe designer
For Dashboard Manager setup, you need to first setup BusinessObjects Enterprise Performance Management repository which is diff from BusinessObjects repository. Go through following guide for setting it up
After completing the EPM Repository setup, you need to design universe, called as “Metric Universe” for Dashboard/Performance Manager
I’m not sure you need BOE to get Designer. Since Dashboard Builder is included with CR Server and the Analytics require a universe then you should have Designer with CR Server.
For the OP, this is not Crystal Reports Designer or Business Views Manager. It is a Business Objects product called Designer. It should be available with yoiur installation under the CR Server Group in windows
Did you ever get this working? I have the same problem. When i click define query nothing happens. I have not set up any universes. Do I need to do this?
You use a client tool named Designer. It should be available from the Busioness Objexcts XI 3.1 | BusinessObjects Enterprise folder on your computer if yoiu have the client tools installed. If you haven’t installed Client Tools on your computer yu should be able to execute it from the same location on the server.
