I want to use an InfoCube as a source in Business Objects Explorer. So I defined a universe on top of the InfoCube using Information design tool along with some calculated columns (similar to calculated key figures in BEx query).
The indexing on the Information Space used to work fine with the default measures that come from the InfoCube but when I started using the newly created calculated columns in the Information Space, the indexing runs forever and never finishes.
I went back to the data foundation of the universe and defined the primary keys for all dimension tables; I maintained all non-measure fields as Foreign Keys in the fact table. (these were not marked by default when I used the InfoCube as the source)
Is this a performance issue or a bug, please do provide your advice.
gramesmith (BOB member since 2014-12-11)
(BOB member since 2002-06-20)
