hi,
i need the way how the incremental load and delta load works in rapidmarts.
if any one can get the wiki links for the this issue it will be help full to me.
imrankhan (BOB member since 2012-02-08)
hi,
Best will be to look at the delta dataflows yourself and try to understand them. It is different for every table as the way to identify changes is different in the source for each.
In other words, there is no generic method in SAP, hence not in the RapidMart.
Werner Daehn (BOB member since 2004-12-17)
Hi Werner,
but in the rapidmarts we will follow the functionality of using first and delta loads,
so based on the table AW_JOB EXECUTION it will work.but here how does it perform this actions based on that table.
can u give me a brief idea abt how this will load data into first and delta.
Via the status table the global variable $G_SDATE and $G_EDATE are set and it is the responsibility of the delta dataflow to load all changes that happen in this window.
Many dataflows, especially the one based on smaller tables, simply read all the source data and feed it into a Table_Comparison transform to figure out all changes - including the ones that happened in that delta window.
Others might right CDHDR table, others have a timestamp column you can trust and no deletes will happen in, others…
Control Tables
AW_JOBEXECUTION
AW_FIRST_RUN_DATE
Global Variables
$G_SDATE
$G_EDATE
$G_LOAD_TYPE
Job Level functions that read/write to control tables
AW_StartJob
AW_EndJob
RM_PutFirstRunDate
Job Level Scripts that call the functions
InitializeJob calls AW_StartJob
EndJob calls AW_EndJob
‘FIRST’ run example
$G_SDATE = ‘2000.01.01’
$G_EDATE = sysdate()
$G_LOAD_TYPE = FIRST
‘DELTA’ run example
$G_SDATE = based on last successful completion of the ETL at the job level
$G_LOAD_TYPE = DELTA
***NOTE if your FIRST run resulted in an error it is best to re-run in FIRST mode otherwise a DELTA would ensue, using the start date of the failed FIRST this could cause slow performance as the data would be subject to DELTA logic (i.e. Target Based comparisons)
SalH (BOB member since 2010-11-09)
This is great and helpfull to me.
