Increasing Excel Row Limitation 65K
Is there any way we can increase the Excel row limitation from 65K (65536) rows to bigger number.
Vijay
vijaykollu :us: (BOB member since 2003-05-08)
No, you will have to find some workaround…
Excerpt from MS Excel docs
Feature                           Maximum limit
Open workbooks                    Limited by available memory and system resources
Worksheet size                    65,536 rows by 256 columns
Column width                      255 characters
Row height                        409 points
Page breaks                       1000 horizontal and vertical
Length of cell contents (text)    32,767 characters. Only 1,024 display in a cell; all 32,767 display in the formula bar.
Sheets in a workbook              Limited by available memory (default is 3 sheets)
Colors in a workbook              56
This is the status of current version of office (2003 a.k.a 11)
Beta of next version of Office (Office 12) has nearly the same limitations.
shamit (BOB member since 2004-07-01)
The work around is, Save the file as .txt/csv then open it using Ultraedit tool.
You can download this tool for free at http://www.ultraedit.com/downloads
Vijay
