Increase Rank limitation
Hi All
When I try to give ranking for a particular column, it allows me to enter only 100 is the maximum value. Is it possible to extend this limit more than 100. If i hear any suggesstions, I will be glad. Thank Q.
Ravi.
______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
Did you also try to use the RANK function and sort descending on the result? I’m not sure if this could work, but you can at least get a ranked list of all your data.
Walter.
ravichandiran pazhani schrieb:
Hi All
Ravi.
