There is one approach I thought of which may not be the best or the
cleanest.
- Create and execute a script as follows :
Sub Main
Application.Variables.Item(“ReportName”).Value = ActiveReport.Name
End Sub
Now define the formula in the cell as
=ApplicationValue(“ReportName”) -
Every time the script is excuted, the variable ‘ReportName’ is set to
the name of the active Report Tab.
If I think of better methods, I will let you know. I have not yet figured
out a way to have a cell execute Script Functions.
Hope this helps.
P.S.Mohan
Original Message from SMAU@chevron.com @ HUB on 04/07:
Is there any way to incorporate the “ReportName” (the value that appears
on the tabs that separate reports in a document) into the header (or
title) of the report itself? It seems to be missing from the variables
available in the Formula editor.TIA,
Steve Aultman
Chevron Info Tech Co.
