I have two Objects in the report both from different data provider and they are in different context in the universe level. Iam not able to create a new object combining both the objects like when isnull of one object the other one in the report level. It says Incompatible Combination of Objects. Tell me a solution, its user requirement?
Essentially if the objects in question are dimension objects and are from different queries, then you cannot use them in a variable or formula. You have to make sure they are linked, or that they are detail objects related to linked dimensions.
Both the data providers are already linked and i have even tried combining them in a single report varaibale by creating two details objects respectiveley for each dimension objects. This didnāt work out!!!
