Xcelsius Guru,
The selector lets you pick the single filtered row to drill down. Is there a way you can create an option called where it selects all the filtered rows for drill down?
for example: Select a type Col1 Col2 Col3 All
manipra (BOB member since 2008-12-18)
Hi manipra, please look at this link https://bobj-board.org/t/119248
in which you’ll find the solution I’ve already posted. If you need something else, just let us know.
Hope this helps,
Luca Spinelli (BOB member since 2008-08-27)
