I am currently using BO version 4.1 and testing BO version 4.14. I’ve been
trying to export a universe that has 137 list of values (.lov files), to the
repository. When I try to import the universe, only 111 list of values
(.lov files) are imported. I checked into the supervisor module to see how
many .lov files are in the repository, and it shows there are 137, so the
problem seems to be in the importing process.
I’ve done some test and found out that both versions of BO (4.1 and 4.1.4)
are only letting me import a max of 111 .lov files. Has anyone seen this
before? And if so, is there a way to make it import all the 137 files.
Any feedback would be appreciated…thanks!
Nikhil (Nik) Kharva
Core Concept, Inc./Matrix
On assignment at BellSouth Cellular Corp.
Voice 770/351-1356
the
Do you really need to export 137 lov files? LOVs only need to be exported
with the universe when they have been modified in Designer. Default LOVs
do not need to be exported with the Universe.
MARK DAVIES
Blueprint Management Systems Ltd
Web: http://www.bpms.co.uk
