Implementing ANSI join condition in Universe
Hi ,
I have ANSI join condition like below
Select …
FROM
CUS_REF_DATA,
PRO_VC,
PRO_PO left outer join HS_FR_VC ON PRO_PO.SIT_ID IN (HS_FR_VC.SIT_ID , HS_FR_VC.SIT_ID2)
WHERE
( CUS_REF_DATA.GRC=trim(PRO_PO.GR)
and CUS_REF_DATA.MCN=trim(PRO_PO.MC)
and CUS_REF_DATA.SOC=trim(PRO_PO.SO) )
AND ( PRO_PO.SIT_ID=PRO_VC.A_SIT_ID or PRO_PO.SIT_ID=PRO_VC.Z_SIT_ID)
Currently I have checked the “Do not generate SQL before running” box inorder to protect my query… I have no idea on how to implement that ANSI left outer join condition in my designer universe.
BO version - 6.5.1 — Oracle 9i version
Can someone suggest me in detail how to implement this logic in Designer.
Thanks in Advance
Canton (BOB member since 2006-10-16)
In your universe, change the ANSI92-parameter (File, Parameters…, tab “Parameter”) to Yes. This will make the joins in your SQL ANSI-style.
jobjoris :netherlands: (BOB member since 2004-06-30)
Hi Job,
Thanks for ur comments.
I want to know how to implement the below join condition.
How do I make the left outer join in the universe while I am in the join dialog box, like the below one.
I set the parameter ANSI92 to Yes…then I went to Join dialog box, when I made the join PRO_PO.SIT_ID with HS_FR_VC.SIT_ID , HS_FR_VC.SIT_ID2 its taking as between in the expression box.
Im gettinng expression like this “PROVG_PORT.SITE_ID between HSPS_FRS_PVC.SITE_ID and HSPS_FRS_PVC.SITE_ID2”
But I dont want this way of generation… can you explain in detail on the steps to follow, even I checke with the Help document…There is no enough information.
