Images location and relocation
Hello,
I work for a University and I have a directory on our network that contains the photographs of each of our students. I have done some proof-of-concept work that has allowed us to create ‘picture sheets’ through WebI with images of all the students on a given course.
My problem is that this proof-of-concept involved copying some images to \ProgramFiles\Businessobjects\Businessobjects11\Images on our server. In production, this is not possible as there are gigabytes of images, and more images are added frequently.
I’ve tried (and failed) to be clever, using a NTFS junction point to mount a UNC network resource to a subdirectory of the \Images directory. Has anybody else attempted (or succeeded) in doing this?
If I can’t do this, the next option is to change the location that boimg:// refers to from \ProgramFiles\Businessobjects\Businessobjects11\Images to the network location. Does anybody know where this default images path is set, and if it can be changed on the server?
Any advice is greatly appreciated!
David
dra4 (BOB member since 2006-01-20)
Try with this.
/BusinessObjects Enterprise 11.5/Images
Kamalini :india: (BOB member since 2007-10-11)
Hello,
I don’t understand what you are suggesting. I know where the directory is, I’m trying to get BO to look somewhere else.
Any ideas?
David
Did you get the answer?
Kamalini
Yes, sorry for not updating earlier.
BO knowledge base article 4330365 explains that you need critical hotfix 16, and then you can change the default location for images.
It’s not the best route, but at least it will work!
David
You can change the location of boimg by doing the following:-
  1. Stop the “WebIntelligence Report Server”
  2. Right click and choose “Properties”
  3. Add “-images C:\images” the to commad (where C:\images is your required location)
  4. Start the service.
I have successfuly done this. However, I would like to change the dashboard images folder to the same location but I can’t find how to do this. Does anyone know if there is a way of doing this for dashboard images?
Cheers,
clarej :uk: (BOB member since 2008-01-22)
I would also like to keep all the images in one location and use a relative path to display these old friend. I will let you know if I get anywhere after some diggin. BO are tinkers for spreading images over multiple locations.
superdooperdoop :o
YPVISA (BOB member since 2007-03-14)
Did you ever find out about changing image location pointers?
Roland
RolandR :netherlands: (BOB member since 2009-10-23)
CHF 16 did what I expected, and allowed me to change the location to a UNC path in the WebIntelligence Server via the CMC. This fixed the issue I had.
Thanks, dra4!
