IIS configuration
BOXI R2
Win 2003 Server
IIS
SQL Server 2005
After installing BOXI, everything seams to be working fine, client tools connect to DB, but when I go to default site via browser, I get page cannot be found.
http://hostname/businessobjects/EnterpriseWebTools/AdminLaunch/default.aspx
Thanks in advance
irehman (BOB member since 2007-12-01)
You already modified the web.config files on both locations i suppose.
Does Infoview login fine? Do have the CMC link for java as well? Does that work?
Abishek :us: (BOB member since 2004-12-09)
No, I have not, what needs to be done there?
Actually i should have asked this my first response.
Are you planning to implement SSO using IIS? Are you bale to login using the java link?
No, I’m not implementing SSO. I have not checked Java link. What is the default link?
I do not have the XI R2 link handy as i am on 3.1. You can logon to the server
Start->Programs->Business Objects->Infoview using Java
Click on the link and it should get you to the default page.
I did not installed tomcat, so I don’t have Java.
So whats happening when you click on
Start->Programs->Business Objects->Infoview using .NET
Page cannot be found.
I do see the directory structure in IIS, so I don’t know what is wrong.
There could be number of reasons. Do you see any useful information in the Event logs or Event vieer? Did you restart the box after the install. I think it has to do with Web component adapters (IIS). You could try to uninstall and re-install web component adapters using the BO cd’s.
Yes, no luck.
